Hello,
I’m using the roster management component. Successfully I can filter which rosters are shown, but the list is updated only when the window is opened or I refresh the script. Dynamically I change a value that indicate which roster I want to use but the management object doesn’t update. Anyone knows if there is something to update or repaint the roster management dynamically?
Thanks in advance.
EDIT:
I tried a hacky way resizing the component but the script (roster Filter) doesn’t reloads, so the same roster is shown.
