Running the following script, everything seems to work except my UPDATE SET Query for t_stamp in table named prevent. See Below.
Here is the MySQL error I get.
File "<event:actionPerformed>", line 16, in <module>
java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(UPDATE
prevent SET (t_stamp) Values (?) WHERE id LIKE ?, [Tue Jan 21 12:57:27 PST 2020, 101.12], , ,
false, false)
caused by Exception: Error executing system.db.runPrepUpdate(UPDATE prevent SET (t_stamp) Values (?) WHERE id LIKE ?, [Tue Jan 21 12:57:27 PST 2020, 101.12], , , false, false)
caused by GatewayException: SQL error for "UPDATE prevent SET (t_stamp) Values (?) WHERE id LIKE ?": You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '(t_stamp) Values ('2020-01-21 12:57:27.166') WHERE id LIKE 101.12' at line 1
caused by MySQLSyntaxErrorException: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '(t_stamp) Values ('2020-01-21 12:57:27.166') WHERE id LIKE 101.12' at line 1
Ignition v7.9.4 (b2017082911)
Java: Oracle Corporation 1.8.0_231
