From one screen I have an open and center popup screen where it sends over a 1 row by 14 column data set. This dataset is stored in the Root Container. What I am trying to do is figure out how to update one of the values in the dataset.
So far this is what I have tried:
value=10
fpmi.dataset.updateRow( {in here i have the event.parent line that points to the dataset in the root container}, 0, “prod_STD”:value)
If I change the zero in the middle of the list of variable to a 1 I get an index out of bound error which I would expect. SO I must have most of the statement correct just not sure why when it runs it does not update the dataset it points to. Any suggestions??
Thanks and have a great day.
