Hi.
I’m currently testing out drawing “Dots”(template) within a Template Canvas.
These “Dots” would act as an overlay over an svg-drawing to represent alarms. Each tag got 2 Associated Properties( xPos, yPos), which are extracted from the alarmStatus() object.
The script is working and the drawing of the dots do happen, but I recieve a few exceptions every time the script is called.
Anyone able to understand what is going on?
Edit: I’m currently manipulating the dataset of the Canvas Template.
As seen in the script, no event is either parsed to the method nor referenced in the script.
NameError: global name 'event' is not defined
[details=Script][code]
def GetActiveUnackedCoordinates():
import system
import re
alarmList = system.alarm.queryStatus(state=[“ActiveUnacked”])
aProp0 = "name"
aProp1 = "xPos"
aProp2 = "yPos"
h1 = "name"
h2 = "template"
h3 = "x"
h4 = "y"
h5 = "width"
h6 = "height"
h7 = "z"
h2Value = 'Dot'
h5Value = '10'
h6Value = '10'
h7Value = '0'
headers = [h1, h2, h3, h4, h5, h6, h7]
aProps = [aProp0, aProp1, aProp2]
dataList = []
data = []
k = 0
j = 0
while k < len(alarmList):
#Convert to string
alarmToSearch = str(alarmList[k])
while j < len(aProps):
search = r'\b\w*' + aProps[j] + r'=(\w*\b)'
r = re.compile(search)
temporary = (''.join(r.findall(alarmToSearch)))
dataList.insert(j,temporary)
j += 1
data.append([dataList[0], h2Value, dataList[1], dataList[2], h5Value, h6Value, h7Value])
k += 1
j = 0
try:
return system.dataset.toDataSet(headers, data)
except ValueError:
system.gui.warningBox("Something isn't right")
#table = event.source.parent.getComponent("MainSiteCanvas")
#table.data = ds
#return table
[/code][/details]
[details=Expression]
toDataSet(
runScript ("project.AlarmFunctions.GetActiveUnackedCoordinates()", 10000)
[/details]
[details=Exception][code]
12:30:33.409 [AWT-EventQueue-2] ERROR Vision.TemplateCanvas - Error invoking extension method.
org.python.core.PyException: Traceback (most recent call last):
File “”, line 14, in initializeTemplate
NameError: global name ‘event’ is not defined
at org.python.core.Py.NameError(Py.java:260)
at org.python.core.PyFrame.getglobal(PyFrame.java:265)
at org.python.pycode._pyx3.initializeTemplate$1(<extension-method initializeTemplate>:17)
at org.python.pycode._pyx3.call_function(<extension-method initializeTemplate>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.PyBaseCode.call(PyBaseCode.java:301)
at org.python.core.PyFunction.function___call__(PyFunction.java:376)
at org.python.core.PyFunction.__call__(PyFunction.java:371)
at org.python.core.PyFunction.__call__(PyFunction.java:361)
at org.python.core.PyFunction.__call__(PyFunction.java:356)
at com.inductiveautomation.vision.api.client.components.model.ExtensionFunction.invoke(ExtensionFunction.java:154)
at com.inductiveautomation.factorypmi.application.components.TemplateCanvas._finishBuilding(TemplateCanvas.java:375)
at com.inductiveautomation.factorypmi.application.components.TemplateCanvas$TemplateLoader.done(TemplateCanvas.java:314)
at javax.swing.SwingWorker$5.run(Unknown Source)
at javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.run(Unknown Source)
at sun.swing.AccumulativeRunnable.run(Unknown Source)
at javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.actionPerformed(Unknown Source)
at javax.swing.Timer.fireActionPerformed(Unknown Source)
at javax.swing.Timer$DoPostEvent.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
12:30:33.414 [AWT-EventQueue-2] ERROR Vision.TemplateCanvas - Error invoking extension method.
12:30:33.418 [AWT-EventQueue-2] ERROR Vision.TemplateCanvas - Error invoking extension method.
12:30:33.422 [AWT-EventQueue-2] ERROR Vision.TemplateCanvas - Error invoking extension method.
12:30:33.425 [AWT-EventQueue-2] ERROR Vision.TemplateCanvas - Error invoking extension method.
12:30:33.428 [AWT-EventQueue-2] ERROR Vision.TemplateCanvas - Error invoking extension method.
[/code][/details]
