The System is a Redundancy system:
Both servers are Windows 2008 R2 64bit
The redundancy mode was set to cold within ignition.
On the slave side all the devices now show disconnected.
if i change it to warm mode and restart ignition the devices on the Slave node are connected again.
In the previous version the Slave would only use one connection to the slave but stay connected in the Cold redundancy mode.
Also on the Slave node i now get the error after restarting ignition:
[ERROR] 14:35:50 SQLTags.TagProviders.Provider[SQLTags].TagStore Error storing tag values.
java.lang.NullPointerException
at com.inductiveautomation.ignition.gateway.sqltags.tagproviders.internal.InternalTagStore.getDBId(InternalTagStore.java:199)
at com.inductiveautomation.ignition.gateway.sqltags.tagproviders.internal.InternalTagStore.internalStoreTagValues(InternalTagStore.java:948)
at com.inductiveautomation.ignition.gateway.sqltags.tagproviders.internal.InternalTagStore$TagValueRedundancyMessageListener.receiveCall(InternalTagStore.java:1213)
at com.inductiveautomation.ignition.gateway.cluster.QueueableMessageReceiver.receiveCall(QueueableMessageReceiver.java:45)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.dispatchMessage(RedundancyManagerImpl.java:619)
at com.inductiveautomation.ignition.gateway.redundancy.state.BackupStateManager._dispatchTask(BackupStateManager.java:351)
at com.inductiveautomation.ignition.gateway.redundancy.state.BackupStateManager$UpdateTaskRunner.run(BackupStateManager.java:374)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:526)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
I have tried to uninstall ignition with a fresh install after and the same porblem persists.
