Upgrade SQL driver
Good day, can someone advise me on this issue? My company's database team moved a database to a new server. Since then, I have not been able to connect again. It is the new SQL 2022 and apparently the problem is the driver I am currently using, sqljdbc4.jar. I need to update it to mssql-jdbc-13.2.0.jre11.jar. What would be the procedure? I do not want to affect the other existing connections. I have Ignition 8.1.33
Go to the Ignition gateway → Config → Databases → Drivers.
After that, you’ll see a list of installed drivers, click the edit button next to the MSSQL one where you’ll see a config page with a button to load a new jar file.
