Upgrade to ignition 8.0.13 : Invalid configuration type hierarchy for node message?
I’ve upgraded a 8.0.12 gateway to 8.0.13, I have some message:
INFO   | jvm 1    | 2020/06/10 09:50:04 | W [t.s.internaljson              ] [07:50:04]: Invalid configuration type hierarchy for node '02dce1a3-f032-4a9c-bf4e-09ed73168aee.f8cc51fc-8062-4adc-8109-37c248ac3920'. Parent entity '02dce1a3-f032-4a9c-bf4e-09ed73168aee' was not found, or not loaded in the correct order. provider=default
what does it means ?
I’ve seen the same thing on 8.0.12 with a cold redundancy pair, the errors stop when the cold standby node is shut down. No idea what the problem is (yet).
I am getting the same problem in 8.0.16, but they are constantly pouring in every second and flooding out useful messages. So, I am just blocking them by setting the logger level for this internaljson to error:
I am getting the same error. Has anyone found out a solution to this problem yet? I’m using 8.1.3.
I am getting this error as well.. I am using edge 8.1.7
Anyone get anywhere with this? I'm seeing it on 8.1.17
Hey Josh, shoot me email to me to support@icontrols.com.au. Have a feeling our support team may have seen this on a call a few months back.
Hey! Has anyone solved this yet? I am running into the same exact issue on 8.1.35 but I can't find many resources.
I also see this on 8.1.39 seemingly when the Main Gateway tries to take back over from the Backup Gateway after a failover.
Then floods the logs with thousands of errors.
Same here on 8.1.17. When I inspect, it says it's an issue with the backup gateway and references a particular tag provider. Does anyone know what causes this and how to eliminate the root issue?
Same here on 8.1.35. Redundant setup. Filling up logs. Anyone have any info on this?
I'll bump this thread as I'm having my logs filled by this. Literally the 500 hundred pages are only this.
I can't see any consequences so far, except for the log flood.
Anyone know how to identify the “node” or the “parent entity”?
I’ve taken a look at tags and UDT definitions from a high level and didn’t find anything obviously wrong.
This error flooded the logs so much that the gateway crashed. @pturmel, any thoughts on this one? Seems like the issue has been around for some time.
I've never seen this one myself. I vaguely recall something like this in a release note.
As some said in this thread, it seems to be linked to redundant failover. 2 other threads I think are worth checking out.
An IA rep responded in this thread
Some of the messages indicate that it started after an upgrade on the system. If you can safely do it, I would break redundancy, upgrade both systems to the same version and then re-establish redundancy and see if it's fixed. You can also contact support and have them look at the backend db. Of course, make a gateway backup before trying this.
