Upgraded 8.0.5 -> 8.0.7 OPC no longer connects
UaException: status=Bad_NonceInvalid, message=nonce must be at least 32 bytes
at org.eclipse.milo.opcua.stack.core.util.NonceUtil.validateNonce(NonceUtil.java:176)
at org.eclipse.milo.opcua.stack.core.util.NonceUtil.validateNonce(NonceUtil.java:162)
at org.eclipse.milo.opcua.sdk.client.session.SessionFsmFactory.activateSession(SessionFsmFactory.java:878)
at org.eclipse.milo.opcua.sdk.client.session.SessionFsmFactory.lambda$configureActivatingState$17(SessionFsmFactory.java:345)
at com.digitalpetri.strictmachine.dsl.ActionBuilder$PredicatedTransitionAction.execute(ActionBuilder.java:76)
at com.digitalpetri.strictmachine.StrictMachine$PollAndEvaluate.lambda$run$0(StrictMachine.java:207)
at java.base/java.util.ArrayList.forEach(Unknown Source)
at com.digitalpetri.strictmachine.StrictMachine$PollAndEvaluate.run(StrictMachine.java:198)
8.0.7 (b2019122014)
Azul Systems, Inc. 11.0.5
please help.
TL;DR: server you're connecting to is out of spec. Upgrade to 8.0.8 nightly or downgrade.
