Hi, my OPC connections faulted after I upgraded Ignition to 7.9.5. I have tried setting the “Endpoint Address” setting to “localhost” and checking the “Allow Anonymous Access”, restarting the OPC-UA module after both, but to no avail.
I had made a backup of the Gateway prior to upgrading, and I restored this backup, and the same problem persists. Any ideas on this? Apologies if I am missing something obvious here! (although I hope that’s the case)
The error I am seeing is,
“GatewayException: UaException: status=Bad_ConfigurationError, message=no matching endpoints found”
Thanks in advance.
