Upgraded to 7.1.3 and when I launch the designer I get " Error Loadling hook class “com.inductiveautomation.vision.activeXDesignerHook” for module “ActiveX”
Once designer loads, there is no Active X componet in the tabs.
I stopped and restarted the gateway, but that did not help.
Here is the error.
com.inductiveautomation.ignition.common.modules.ModuleLoadException: Error loading hook class “com.inductiveautomation.vision.activex.ActiveXDesignerHook” for module “ActiveX”.
at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadModules(IgnitionDesigner.java:763)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.startup(IgnitionDesigner.java:272)
at com.inductiveautomation.ignition.designer.DesignerStartupHook$2.run(DesignerStartupHook.java:220)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
Caused by: java.lang.NoClassDefFoundError: com/inductiveautomation/factorypmi/designer/palette/model/PaletteItem
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadModules(IgnitionDesigner.java:758)
… 10 more
Caused by: java.lang.ClassNotFoundException: com.inductiveautomation.factorypmi.designer.palette.model.PaletteItem
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
… 13 more
