Upgrading Versions
I am missing something.
I was running the demo version of 7.09 and upgraded to 7.1 and now the opc tags are not being scanned.
I backed up the project before trying to upgrade.
I upgraded by just executing the Windows installer for 7.1.
The web server is running. The context is running. The devices say they are connected.
What am I doing wrong?
Thanks for the help.
Dennis
Dennis, please give us a call at (800) 266-7798 so we can take the problem. We need more information to figure out why the tags are not updating.
It will be a while. I am tied up on something else.
Earlier upgrades seemed to go without a hitch. The last couple of times I had issues.
Talk to you later.
Dennis
What are the versions of each module in Ignition? You can find these in the gateway config section under Configuration -> Modules.
The OPCUA Server says that it is faulted:
java.lang.Exception: Error during ActivateSession: Bad_UserAccessDenied
com.inductiveautomation.xopc.client.ua.ActivateSession.activateSession(ActivateSession.java:162)
com.inductiveautomation.xopc.client.ua.UAClient.connect(UAClient.java:95)
com.inductiveautomation.xopc.client.sropc.OPCUAServer.connect(OPCUAServer.java:394)
com.inductiveautomation.xopc.client.sropc.OPCUAServer.verifyConnectionState(OPCUAServer.java:417)
com.inductiveautomation.ignition.gateway.opc.OPCManagerImpl$ServerWrapper.verifyConnectionState(OPCManagerImpl.java:663)
com.inductiveautomation.ignition.gateway.opc.OPCManagerImpl$OPCConnectionKeepalive.run(OPCManagerImpl.java:550)
com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:450)
java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
java.util.concurrent.FutureTask$Sync.innerRunAndReset(Unknown Source)
java.util.concurrent.FutureTask.runAndReset(Unknown Source)
java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$101(Unknown Source)
java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.runPeriodic(Unknown Source)
java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
java.lang.Thread.run(Unknown Source)
Subscriptions
OPC-UA Drivers is 1.09
I’ll swap that out and see if that fixes it.
Dennis
I uninstalled and then reinstalled 7.1.
No errors showed with new naked installation.
I restored a backup taken in the backup/restore section and now there is an error with the opcua connections.
IgnitionOPCUA is faulted. It says Error during ActivateSession:Bad_UserAccessDenied
details:
com.inductiveautomation.xopc.common.UAException: null
com.inductiveautomation.xopc.common.stack.TCPChannel.sendAsynchronous(TCPChannel.java:314)
com.inductiveautomation.xopc.common.stack.TCPChannel.send(TCPChannel.java:295)
com.inductiveautomation.xopc.common.stack.TCPChannel.getEndpoints(TCPChannel.java:163)
com.inductiveautomation.xopc.common.stack.TCPChannel.getEndpoints(TCPChannel.java:149)
com.inductiveautomation.xopc.client.sropc.OPCUAServer.getEndpoint(OPCUAServer.java:436)
com.inductiveautomation.xopc.client.sropc.OPCUAServer.connect(OPCUAServer.java:377)
Subscriptions
default.0 @1000ms enable live values
Address Last Value Quality Timestamp
[IgnitionOPCUA][504WrapperRMplcA]Global.HMI_LastScanTime null Bad_NoDataAvailable 2010-05-12 09:41:42
[IgnitionOPCUA][504WrapperRMplcA]Global.HMI_MaxScanTime null Bad_NoDataAvailable 2010-05-12 09:41:42
[IgnitionOPCUA][504WrapperRMplcA]Global.MCM1_ScanTime null Bad_NoDataAvailable 2010-05-12 09:41:42
[IgnitionOPCUA][L504_CIP_CONTROL]Global.BATTER_HOLD_TANK_HOMOG_DIVERT_1_V412.is_Closed null Bad_NoDataAvailable 2010-05-12 09:41:42
[IgnitionOPCUA][L504_CIP_CONTROL]Global.BATTER_HOLD_TANK_HOMOG_DIVERT_1_V412.is_Open null Bad_NoDataAvailable 2010-05-12 09:41:42
[IgnitionOPCUA][L504_CIP_CONTROL]Global.BATTER_HOLD_TANK_HOMOG_DIVERT_2_V413.is_Closed null Bad_NoDataAvailable 2010-05-12 09:41:42
[IgnitionOPCUA][L504_CIP_CONTROL]Global.BATTER_HOLD_TANK_HOMOG_DIVERT_2_V413.is_Open null Bad_NoDataAvailable 2010-05-12 09:41:42
[IgnitionOPCUA][L504_DEPOSITOR]Global.Auto null Bad_NoDataAvailable 2010-05-12 09:41:42
[IgnitionOPCUA][L504_DEPOSITOR]Global.WorkData.Name.STRING null Bad_NoDataAvailable 2010-05-12 09:41:42
[IgnitionOPCUA][L504_DOUGH_HOMOG]B3:2 null Bad_NoDataAvailable 2010-05-12 09:41:42
[IgnitionOPCUA][L504_INJECTOR]Global.Auto null Bad_NoDataAvailable 2010-05-12 09:41:42
[IgnitionOPCUA][L504_INJECTOR]Global.WorkData.Name.STRING null Bad_NoDataAvailable 2010-05-12 09:41:42
[IgnitionOPCUA][L504_OVEN]Global.Carriers_Visible_at_DEPOSITOR.Carriers_Visible_at_DEPOSITOR[0] null Bad_NoDataAvailable 2010-05-12 09:41:42
[IgnitionOPCUA][L504_OVEN]Global.Carriers_Visible_at_DEPOSITOR.Carriers_Visible_at_DEPOSITOR[1] null Bad_NoDataAvailable 2010-05-12 09:41:42
[IgnitionOPCUA][L504_OVEN]Global.Carriers_Visible_at_DEPOSITOR.Carriers_Visible_at_DEPOSITOR[2] null Bad_NoDataAvailable 2010-05-12 09:41:42
[IgnitionOPCUA][L504_OVEN]Global.Carriers_Visible_at_DEPOSITOR.Carriers_Visible_at_DEPOSITOR[3] null Bad_NoDataAvailable 2010-05-12 09:41:42
[IgnitionOPCUA][L504_OVEN]Global.Carriers_Visible_at_DEPOSITOR.Carriers_Visible_at_DEPOSITOR[4] null Bad_NoDataAvailable 2010-05-12 09:41:42
[IgnitionOPCUA][L504_OVEN]Global.Carriers_Visible_at_DEPOSITOR.Carriers_Visible_at_DEPOSITOR[5] null Bad_NoDataAvailable 2010-05-12 09:41:42
[IgnitionOPCUA][L504_OVEN]Global.Carriers_Visible_at_DEPOSITOR.Carriers_Visible_at_DEPOSITOR[6] null Bad_NoDataAvailable 2010-05-12 09:41:42
[IgnitionOPCUA][L504_OVEN]Global.Carriers_Visible_at_DEPOSITOR.Carriers_Visible_at_DEPOSITOR[7] null Bad_NoDataAvailable 2010-05-12 09:41:42
[IgnitionOPCUA][L504_OVEN]Global.Carriers_Visible_at_DEPOSITOR.Carriers_Visible_at_DEPOSITOR[8] null Bad_NoDataAvailable 2010-05-12 09:41:42
[IgnitionOPCUA][L504_OVEN]Global.Carriers_Visible_at_DEPOSITOR.Carriers_Visible_at_DEPOSITOR[9] null Bad_NoDataAvailable 2010-05-12 09:41:42
[IgnitionOPCUA][L504_OVEN]Global.Drive_on_indicator null Bad_NoDataAvailable 2010-05-12 09:41:42
[IgnitionOPCUA][L504_OVEN]Global.Trays_per_minute null Bad_NoDataAvailable 2010-05-12 09:41:42
[IgnitionOPCUA][L504_OVEN]Global.Wonderware_Recipe_Name.STRING null Bad_NoDataAvailable 2010-05-12 09:41:42
<< < 1 2 > >> Total subscribed items: 30
default.1 @10000ms enable live values
<< < > >> Total subscribed items: 0
Another place says:
Error getting endpoint response from url “opc.tcp://localhost:4096/iaopcua”
Could this be caused by Windows Firewall?
Dennis
It looks like your username and password are setup wrong. I have a couple things for you to check:
  1. In the module status area of the gateway (localhost:8088/main/web/status/modules) can you check the version number of all your modules and post those here?
  2. In the OPC-UA settings area (localhost:8088/main/web/config/xopc.settings) what authentication profile is set? It should be “opcua-module” with allowed roles “ReadWrite”.
Then in the security > authentication area (localhost:8088/main/web/config/security.auth) you should have a “opcua-module” profile. This profile should have a user called “opcuauser”.
The default password is “password”. In your connection to the OPC-UA server (localhost:8088/main/web/config/opc.connections) you should have the previous username and password specified.
This is all done by default but I suspect by restoring an older gateway backup things are getting a little jumbled.
