Use if else syntax to input the value
I use if condition to input the value, but the result shows the error.
Thanks for help.
Python is a structured language so whitespace matters. Notice the tabs.
filename = ...
if filename is None:
    #do something
else:
    #do something else
Hi, sorry I didn't get it. Should I delete the whitespace?
		if filename is not None:
		fileid=self.getSibling("fileidnone").props.text
		else:
		fileid=elf.getSibling("fileid").props.text
You'll need to do an intro to python course to ease your scripting learning curve.
def runAction(self, event):
	else:
https://docs.python.org/2.7/tutorial/introduction.html#first-steps-towards-programming
Thanks for your help. I'm learning and keeping moving.
