I am trying to use a named query to update a value in one of four columns in a MySQL database table. However it looks like if I use a string parameter to tell the query the field to update it doesn't work. The value parameter works fine.
Is this possible at all?
Did not find this case in any of the other topics...
Thanks.
edited typo
Change Type from Value to QueryString and re-drag the parameter into the query. Be careful as the inputs are not sanitized
Use type QueryString:
Then:
SET
{entryName} = :entryValue
...but beware of SQL injection--don't do it if entryName is generated by user input!
Thank you so much! Don't know why I looked at forum first. Thanks for the time. D
