How can I drop the methods defined in the Project Library in Tag’s scripting scripting?I use it like this in the following figure, but it doesn’t work, plus print still won’t work
Tags are gateway scoped. You’ll need to put your script library into the project that you’ve defined as your global scripting project.
Print statements work, they just output into the wrapper.log (as again, these run in the gateway, not the client)
I see. Thank you
Just for reference and posterity:
from here:
https://docs.inductiveautomation.com/display/DOC80/Gateway+Settings
