Use PDF from DB to view in PDF viewer in perspective using WebDev
I want to display a PDF in PDF viewer in perspective that is saved in DB in blob format using WebDev.
this is the code I wrote in WebDev doget()
my_pdf=system.db.runNamedQuery( "folderName/myNamedQuery" , {})
return {'contentType':'application/pdf','bytes':my_pdf}
The above code doesn’t seem to work
how can this be done?
Named queries return a dataset. You need to pull the blob content out of the dataset. Something like this:
myds=system.db.runNamedQuery( "folderName/myNamedQuery" , {})
my_pdf = myds.getValueAt(0, 'myBlobColumnName')
You might also find this helpful:
