Use system.db.runUpdateQuery with variable value counts
Hello,
I’m running system.db.runUpdateQuery with variables, which works, however, I’d also like to make the number of VALUES variable, which isn’t working for me. This is what I have so far:
#Variables########################################
SqlLabels = (																			#Add SQL column labels here
	'Line',
	'Spool',
	'HeightMin',
	'HeightMax',
	'HeightAvg',
	'HeightDev',
	'HeightCpk'
SqlValues = (																			#Add values for SQL here, these are not hard coded in real program
	' 100',
	' 200',
	' 300',
	' 400',
	' 500',
	' 600',
	' 700'
#Definitions##################################################
def convertTuple(tup):  #converts tuple to string
    str =  ','.join(tup)
    return str
def transactionInsert(Labels, Values): #runs SQL transaction, adds row and populates columns with data
	import system
	system.db.runUpdateQuery("INSERT INTO DataTable (" + Labels + ")  VALUES (%s, %s, %s, %s, %s, %s, %s)" %Values)
#Program##################################################
Headers = convertTuple(SqlLabels) #converts SqlLabels tuple into string for transaction
transactionInsert(Headers, SqlValues) #runs transaction
How can I make this part variable length? VALUES (%s, %s, %s, %s, %s, %s, %s)
I can make a string, but it doesn’t seem to work with a string. If I convert the string to a tuple or list, it comes out in the wrong format too:
Str = ""
for x in range(len(SqlLabels)):
	Str += " %s,"
	print Str
Str = Str[:-1]
#Str = Str + ")"
print Str
Lis = Str.split(',')
print Lis
Tup = Str.partition(',')
print Tup
results in:
%s,
%s, %s,
%s, %s, %s,
%s, %s, %s, %s,
%s, %s, %s, %s, %s,
%s, %s, %s, %s, %s, %s, %s,
[’ %s’, ’ %s’, ’ %s’, ’ %s’, ’ %s’, ’ %s’, ’ %s’]
(’ %s’, ‘,’, ’ %s, %s, %s, %s, %s, %s’)
I think this post may help you.
Instead of inserting a ‘%s’ for each value that you want, build a single string representing the value list that you need. Similar to how you converted the Tuple to a string.
    system.db.runUpdateQuery('INSERT INTO DataTable (%s) VALUES (%s) ' % (','.join(Labels),','.join(Values))
There is no need to import system, that is done automatically for you.
Be careful here, as this approach can be open to SQL Injection.
@lrose
It works like this, this query:
system.db.runUpdateQuery('INSERT INTO DataTable (%s) VALUES (%s) ' % ((Labels),','.join(Values)))
produces this:
system.db.runUpdateQuery(INSERT INTO DataTable (Line,Spool,HeightMin,HeightMax,HeightAvg,HeightDev,HeightCpk) VALUES ( 100, 200, 300, 400, 500, 600, 700) , , , false)
Thanks so much for your help!
Yeah, I assumed that Labels was some type of a data structure like a list or tuple not a string.
Either way, glad you got it working.
