hello everyone again!
I have a question, maybe it's dummie for some, for me it is ;). I would like to have a control of the income for users who enter the Vision, which can not access in a range of hours, for example from 14:00 to 18:00 can not access the Vision.
I have made an example schedule with this configuration
it is 14:33 in my country
looking at the configuration I am allowed to access until 14:30 and being 14:33 I still have access to the vision when I should not.
I have also configured it in config < user < roles
Is there an internal script that I should run as well, or should it work the way I have it?
regards.
Did you enable "Schedule Restricted" in the User Source config itself?
What version of Ignition are you using? Let me see if I can make it work on my 8.1.20 setup.
EDIT: I notice that the Weekdays 0000-2400 option is checked by default, I'm wondering if having that on is causing issues. I'm going to leave it on for my testing, and then test without it if I can't make the schedule work.
It works for me on 8.1.20. I set up a schedule that is only active during noon:
Set up a user with the schedule:
and it won't let me log in, as expected.
If I change Mr. McCree's schedule to Always, it logs in just fine. I'm at a bit of a loss here to be honest. Maybe I did something you missed?
I don't know what happened, but I decided to do a new schedule "test" and it worked.
Maybe it's because I closed the Vision client and reopened another one, I don't know, but it worked just as you said.
thank you very much Felipe
Honestly, this is probably the actual solution. In my experience it often takes a restart of the client to "notice" certain config changes.
