My users get logged out after about 10 minutes from their perspective session. The inactivity logout setting in project settings is set to disabled. Easy enough to use the bottom expansion to log back in but I'd rather just not log off as they will have to be logged in for long periods of time. No errors are thrown. This even happens when I am running the session on the same device as the server. I don't think there is a network issue. What else should I be looking for?
Also check the following within gateway config @ IDP settings:
- Session Inactivity Timeout
- Session Expiration
Thank you!
I was sure there must be a setting I was missing somewhere. That seems like it was probably it. I'll guess I'll know in 30 minutes.
