Hi, I’m having a problem using the User Management Component. I can use it normally in the designer, it allows me to add, delete and modify users and roles.
My problem is in the client. This component shows me all users and roles, but all buttons are disabled, and in the top left corner shows me a Tag symbol with a green question mark, as for “unknown” status.
I’ve already checked the “Allow User Admin” in Gateway Settings.
I would appreciate any help. Thanks!
In Project Properties > Client > Permissions do you have User Management enabled?
I didn’t noticed that. Thanks!
@jadachi I had the same issue, glad you post here, thanks!
@ethomason Thank you for your solution!
Hi
@jadachi I also had the same problem,
@ethomason Thanks for your solution! the problem is solved.
Thanks!
