Hi, I have a project in version 8.0.10 using the User Management component on an Internal user source. I have the Mode property setup so that only the administrator level user can access the Manage Users mode, while other user levels can only access the Edit Current mode. The other users level should only be allowed to change their passwords, and not other user properties like username, First Name, and Last Name. I’ve set the component properties such as Contact info Editing Enabled and Schedule Adjustments Enabled to be admin only, however the other users can still change the other user properties besides password.
Therefore, I’m wondering if there is another component property for the User Management component, or if scripting may be used. Checking some other forum topics, it seems scripting password changes with internal user sources are limited.
