User menu privileges
Hello!
At the moment when the user access the project is enabled to use some parts of the menu.
so if not enable appear the prohibited icon on rollover
I did it enabling those parts from numbers in the user notes with:
  if notes:
	            try:
	                parts = notes.split(";")
	                for part in parts:
	                    if part.startswith("zones:"):
	                        zone_numbers = part.split(":")[1]
	                        enabled_zones = set(zone_numbers.split(","))
	                    elif part.startswith("access:"):
	                        # Get the access value and determine enabled items
	                        access_numbers = part.split(":")[1]
	                        enabled_access = [int(digit) for digit in access_numbers]
I would like to know if is possible to hide those parts of the menu instead, so they don´t appear to the user with no privileges.
Thanks and happy Christmas,
Alejandro
If you build your menu's items by script
I can see three easy choices:
  1. Set items.n.enabled : true / false depending on role.
  2. Set items.n.style.display : none to hide the option with CSS.
  3. Omit the option from items.
That doesn't sound like a good plan. You should be using roles not users for ease of maintenance and so you don't have to edit the project to add a user.
If your menu is fixed (rather than scripted) then you can use an expression binding on enabled or style.display and something like
hasRole | Ignition User Manual to enable or show the option.
I think the opposite of display : none would be display : inline.
def runAction(self):
	try:
	    horizontal_menu = self.getChild("root").getChild("HorizontalMenu_0")
	    if horizontal_menu is None:
	        raise AttributeError("HorizontalMenu component not found")
	    # Get the enabledAccess list from the session custom property
	    enabled_access = self.session.custom.enabledAccess
	    filtered_items = []
	    for index, item in enumerate(horizontal_menu.props.items):
	        # Check if index is within the range of enabledAccess
	        if index < len(enabled_access):
	            if enabled_access[index] > 0:  # Add to filtered list if enabled
	                filtered_items.append(item)
	    # Update the menu's items property with the filtered list
	    horizontal_menu.props.items = filtered_items
	except Exception as e:
	    # Log an error message if something went wrong
	    error_message = "Error setting menu item enabled state: {}".format(str(e))
	    system.util.getLogger("HorizontalMenu").error(error_message)
Finally I used this code enabling the menu items I want to use, with visibility class didn´t work.
In my case anything over 0 is enabled
I not using roles because each usr has very specific privileges altough is probably the best way.
