User Source Configuration File Location
Hello,
I just did a clean install of Ignition 8.1.40 and while configuring the gateway I changed the default user source name. This has caused the system to no longer let me log in.
How can I change the user-source settings from the Ignition files to restore access?
Use the gwcmd command line tool's -p option.
Thanks!!!
  1. cd C:\Program Files\Inductive Automation\Ignition
  2. gwcmd -p
  3. Access to the gateway, will prompt for creating a new user.
Don't forget to undo the temporary user source and IdP after fixing your original authentication configuration.
