Hai ,
I need to change the column names in the user source table because doing so causes the authentication to fail.
Is it viable to modify the table?How am i able to authenticate?
Thanks in advance,
Hai ,
Thanks in advance,
Please provide more information. What you starting with, what changes you are making, and why, at the very least.
When I using the below method to insert the value to empid (newly added column ),
its not inserting the value to the appropriate field .(which one I newly added column into the user tabel)
userToGet = system.user.getNewUser("AcmeWest", "mTrejo")
contactInfo = {"email":"mTrejo@acmewest.com","sms": "5551234"}
userToGet.addContactInfo(contactInfo)
userToGet.set("password", "thisIsMyPassword")
userToGet.set("empid", "1000")
system.user.addUser("AcmeWest", userToGet)
Well, that function isn't documented to support custom columns in a user source. The User class, while a PropertySet, has a static list of properties exposed. This is a database table. Use database methods to alter its content.
