Hello.
In one of our tables the user can edit its contents. When they do, the changes get written to a log stored in the database through the onCellEdited Power Table extension function.
Today a user brought up that when he edits a table the log states he made between 9-12 edits, all less then 1 second apart.
I looked into it, there are no loops he could somehow get trapped in. I cant reproduce the issue, and the 4 other users I asked could not repeat the issue.
Our Ignition version is 7.9.10, his Java version is Version 8 Update 191 (same as mine).
I’ve bandaged the issue by adding a locking variable to the table. Essentially if the variable is true (locked) the onCellEdited function skips everything and does nothing. If its false (unlocked) it can do what it should. So when it triggers 9-12 times, only the first locks it and does anything.
However this will likely be a problem with other tables in our system. Is this a known bug, or an issue that that has come up before? Is there a reason an onCellEdited listener would trigger multiple times for a certain user?
As requested, code below
# Gathering relevant data for log
data = system.dataset.toPyDataSet(self.data)
ticket_info = system.db.runPrepQuery("select * from TABLE1 where event_id = ?",[self.log])
owner = ticket_info[0]['nw_owner']
evid = self.log
subj = ticket_info[0]['subject']
site = ticket_info[0]['site']
details = ticket_info[0]['desc']
nsid = ticket_info[0]['netsuiteid']
eventdate = ticket_info[0]['eventdate']
callername = ticket_info[0]['callername']
email = ticket_info[0]['calleremail']
issuetype = ticket_info[0]['issue_type']
priority = data[rowIndex]['priority']
stat = data[rowIndex]['callstatus']
content = ""
user = system.security.getUsername()
def updateNotes(field):
Updates log in the database
Args:
field (str): Field being updated
field = field.replace('_',' ')
parts = field.split(' ')
i = 0
for part in parts:
newpart = part.replace(part[0],part[0].upper())
parts[i] = newpart
i+=1
field = ''
for part in parts:
field += part + ' '
field = field.rstrip()
#add note to ticket to show case is created
#first query the notes for the event
notes = system.db.runPrepQuery("select notes from TABLE1 where event_id = ?",[evid])
note = notes[0][0]
if note is None:
note = ''
#update notes
note += "\n\nTicket Update by %s at %s"%(user,system.date.format(system.date.now(),'EEE, MMM d yyyy - HH:mm'))
note += "\n%s changed to %s from %s" %(field,newValue,oldValue)
#update database
system.db.runPrepUpdate("update TABLE1 set notes = ? where event_id = ?",[note,evid])
if colName == 'callstatus':
query = 'update TABLE1 set `%s` = "%s" where event_id = %d' % (colName,newValue,evid)
#if the status has changed to needs dispatch, set a servicedate of today
if newValue == 'Needs Dispatch':
system.db.runPrepUpdate("update TABLE1 set servicestartdate = ? where event_id = ?",[system.date.format(system.date.now(),'yyyy-MM-dd HH:mm:ss'),evid])
updateNotes('Ticket Status')
if user != owner:
message = "Ticket %d (%s) for %s status has changed from %s to %s by %s. " %(evid,subj,site,oldValue,newValue,user)
result = shared.telegram.sendTicketBotMessage(message,owner)
#if ticket is complete, auto popup the email editor
if newValue == 'Complete':
stat = 'Complete'
if callername is None:
callername = 'Dear Valued Customer'
if issuetype is None:
issuetype = 'Other'
body = callername + ','
body += "\n\nStatus Update on Ticket: %d" %evid
body += "\n\nLocation: %s" %site
body += "\nEvent Date and Time: %s" %system.date.format(eventdate,'yyyy-MM-dd HH:mm')
body += "\nIssue Type: %s" %issuetype
body += "\n\nDetails: \n%s" %details
body += "\n\nCurrent Status: %s"%stat
body += "\n\nAdditional Notes from Operator:\n\n"
win = system.nav.openWindow('Popups/Email Details Default Client',{'to':email,'cc':'','subject':subj,'body':body,'nsid':nsid,'event_id':evid})
system.nav.centerWindow(win)
else:
updateNotes(colName)
system.db.runUpdateQuery(query)
self.data = system.dataset.setValue(self.data, rowIndex, colIndex, newValue)
