Users, Roles set-up
Hello!
In my gateway I pointed the User Source to
In the User Source I made a list of users with the login and password
But I can´t login with these new credentials, only with my original gateway one.
Is there something I´m missing?
Check that your project is using that user source.
Project Properties | Perspective | User Source.
Check the Identity Provider too.
the User Source is already fine
In the Identity Provider configuration should I chang it to ConnetUsers
can´t login with new users credeentials yet
Perspective doesn't directly use any user source. It only uses Identity Providers. Ignition's built-in Identity Provider targets a user source to supply identities. If your Perspective project is set up with an external Identity Provider, then no user source anywhere in Ignition will matter.
