I'm having trouble using a dataset tag as the source for a table component in the reporting module. I haven't found any examples in manual about doing this. The dataset is a parameter in my report, from what I've read, I need to put in a scripting datasource to get it in the table, but it isn't working.
What isn’t working? Are you receiving an error?
Yup. Reports run on the gateway -- they don't have any access to client tags, except where you bind the client tag to a report viewer's parameter.
Hmmm, reports are generated on the gateway, I guess my client tags are the problem. This should be fine if I use system.tag.read to get my client tags and pass them in for parameters with executeAndDistribute. It’s just a pain to design the report to begin with. I guess I will have to create gateway tags to design the report, then delete them.
I was able to create some gateway tags to design with, and they are working as I expected. Thanks @pturmel @ethomason
Hi.
I would like to print a report showing a table populated with a dataset. I have passed the dataset to the report as a parameter and set this up as a data source using the screenshot above.
I can now display rows of the dataset in a simple table using [@data[rowNumber].columnName@]. Is there a better method than individually addressing all the elements? I was hoping I could point the dataset at a table and it would just work! My current solution is OK but since the dataset is of variable length, I will get N/A for empty cells.
Any ideas?
You shouldn’t have to address each element, the table should be dynamic to the data source.
Report - Simple Table - Ignition User Manual 8.0 - Ignition Documentation (inductiveautomation.com)
Thanks. I read the documentation about the simple table but I was unable to get it to work with my dataset.
In the data configuration area, I have set up a script that copies my input parameter (dataset) to a datasource called “Loading”.
data[‘loading’]=data[‘data’]
I added a simple table and set the data key to my datasource “Loading” but the the table is blank at runtime. I know the data is there because the individual addressing works.
What am I doing wrong?
Try using the regular table instead of the simple table:
https://docs.inductiveautomation.com/display/DOC80/Report+-+Table
I tried the normal table but this gives the same result. Do I need to modify the script that copies the dataset to the data source?
Can you post the entire script?
Also a screenshot of how you have the table setup.
