Firstly sorry if this is a very basic issue.
I currently have a connection to a MQTT client (shelly 1)
I am using this shelly UDT.
Connection is established and i can trigger the shelly relay.
When i goto display the status or state of the relay.
the tag .value returns the following expression.
{ "ison": true, "has_timer": false, "timer_started": 0, "timer_duration": 0, "timer_remaining": 0, "source": "http" }
This is due to the tag data type being document
I have a hunch i should be using the expression tab. I put it into tag tab to view the tag binding preview below.
How do i use just one element("ison") of the document/expression to trigger green/red
