Using another column's value as property from same database
I have create a dataset with 2 main columns, tag name and tag path
The TAG_PATH column has value of the tag name (value from NAME column) in it.
Can I use the column NAME as property in cell binding for column TAG_PATH?
Something like,
[default]PROJ/OPC/{NAME}[0]/Value
where {NAME}[0] is the 0th cell under column NAME
No, cell update bindings cannot do indirection or expressions. Just direct tags or properties.
