Hey, I seem to be having an issue getting a named query to use the current value in a client tag, to filter a SQL query i'm doing.
SELECT compressor.comp_name,
compressor.comp_ID,
asset.asset_name
FROM compressor
INNER JOIN asset ON compressor.comp_ID = asset.asset__id
WHERE compressor.comp_name = :CompName
If i create a Value or QueryString parameter pointing to the client tag:
{[Client]SelectedComp} #Currently has value of Selected Compressor in the DB - BristolComp003
I get no results.
If i manually set the WHERE clause to WHERE compressor.comp_name = 'BristolComp003'
It works. Is there something i'm missing as to how to use the client tag properly to filter this named query? Thanks.
