Using Config Panel class Ignition 8.1
I’m trying to develop a config page for my module and so far I’ve learned that I need to extrend a “ConfigPanel” class. However I’m having issues importing it. Does anyone know which dependencies I should have on my Build.gradle.kts? This is the import i’m trying to do
import com.inductiveautomation.ignition.gateway.web.models.ConfigPanel;
You probably want to extend RecordEditForm, not ConfigPanel.
Consider cribbing heavily from the 8.1 example module (that's what it's for):
Thank you Paul! I’m trying to use the example and learn but I’m having a few issues with imports. This one mainly: import com.inductiveautomation.ignition.examples.hce.records.HCSettingsRecord;
isn’t working for some reason.
Replace HCSettingsRecord with your own PersistentRecord implementation from your module.
