Using CSS class to animate individual elements from the drawing object
I am trying to style individual elements in my pump drawing and when I add the style to the object itself it applies to all elements but when I add the style to on specific element it does not work. Below is my current style class and animations:
@keyframes psc-pmpALM-anim {
0%  { fill: #FF000055; }
100% { fill: #FF000088; }
0%  { stroke: #000000; }
100% { stroke: #FF0000; }
.psc-pmpALM path {
animation-name: psc-pmpALM-anim;
animation-duration: 1s;
animation-iteration-count: infinite;
animation-direction: alternate;
animation-timing-function: linear;
.psc-pmpAcked path {
stroke: #FF0000 !important;
fill: #FFBEBE !important;
.psc-pmpW path {
fill: #FFFFFF !important;
.psc-pmpG path {
fill: #B0B0B0 !important;
You need to apply the style to the SVG element itself. You'll probably need to add the styles.classes prop manually
I had already done that, however when I call the style nothing seems to happen. I no longer need this feature in my application, however it would still be something good to know.
Sometimes the fill paint on an element will interfere with style bindings. I usually apply the style and look at it. If the style isn’t showing up I delete the fill paint nodes and see if it’s visible. Sometimes I set the fill paint to transparent. When you delete the fill paint node it usually makes the element totally black. Sometimes I have to set that to transparent and sometimes my style fixes it.
It’s one of those things that can be a little weird as it behaves differently on different drawings. I haven’t dug into it enough to figure out exactly what’s going on because it’s usually quicker for me to just try a few things and see what is working on a specific drawing.
That doesn’t seem to be working as well, it is doing the ‘all black’ behavior that you mentioned.
did you add a style element to that element?
Edit:
Sometimes when you get the black fill you have to leave the paint element and make it fill with “transparent”
It could be the path selector in the rule, try it without that.
