Using DB Table Historian as history provider for edge sync services
Hi, we have a database we use to log several different locations, to segregate the data a bit i wanted to use the DB Table historian to give each remote provider a different provider, but it seems like theese providers refuse connection.
Am i trying to do something that is not supported, everything works when i use the direct Datasource History Provider.
Ok, it seems like the DB table historian was not what i tought it was. To achieve the result i want i think i would have to split the SQL server into multiple DBs and set up several connections to the same database.
As long as each remote edge gateway has a unique name, Ignition will keep track of them within its metadata. You might want to have support look over your shoulder to set this up the first time.
