Using derived tags for nested JSON - structures
Hi, I'm using nested jsonGet() functions to reconstruct data-tags from a read JSON structure.
My input JSON:
[{"SN":[0,0,0,0,0,0,0,0,0,0],"Device_Type":315,"Nominal_Active_Power":125.0,"Output_Type":2,"Daily_Power_Yield":15.8,"Total_Power_Yield":48714,"Total_Running_Time":1285,"Internal_Temperature":34.7,"Total_Apparent_Power":7625,"Total_DC_Power":7.741,"AB_Line_Voltage":604.3,"BC_Line_Voltage":605.9,"CA_Line_Voltage":603.10004,"Phase_A_Voltage":604.3,"Phase_B_Voltage":605.9,"Phase_C_Voltage":603.10004,"Phase_A_Current":8.3,"Phase_B_Current":8.400001,"Phase_C_Current":8.400001,"Total_Active_Power":7.6250005,"Total_Reactive_Power":284,"Power_Factor":100.0,"Grid_frequency_01":50.0,"Work_State_AP1":0,"Alarm_Year":0,"Alarm_Month":0,"Alarm_Day":0,"Alarm_Hour":0,"Alarm_Minute":0,"Alarm_Second":0,"Alarm_Code":0,"Nominal_Reactive":75.0,"Insulation_Resistance":83,"Active_Power_Setpoint":125000,"Reactive_Power_Setpoint":0,"Work_State_AP2":131073,"Meter_Power":-1,"Meter_A_Phase_Power":-1,"Meter_B_Phase_Power":-1,"Meter_C_Phase_power":-1,"Load_Power":-1,"Daily_Export_Energy":4.294967295E8,"Total_Export_Energy":4.294967295E8,"Daily_Import_Energy":4.294967295E8,"Total_Import_Energy":4.294967295E8,"Daily_Energy_Consumption":4.294967295E8,"Total_Energy_Consumption":4.294967295E8,"Daily_Running_Time":215,"Preset_Country":16,"MPPT_1_Voltage":1007.5,"MPPT_1_Current":7.7000003,"MPPT_2_Voltage":6553.5,"MPPT_2_Current":6553.5,"MPPT_3_Voltage":6553.5,"MPPT_3_Current":6553.5,"MPPT_4_Voltage":6553.5,"MPPT_4_Current":6553.5,"MPPT_5_Voltage":6553.5,"MPPT_5_Current":6553.5,"MPPT_6_Voltage":6553.5,"MPPT_6_Current":6553.5,"MPPT_7_Voltage":6553.5,"MPPT_7_Current":6553.5,"MPPT_8_Voltage":6553.5,"MPPT_8_Current":6553.5,"MPPT_9_Voltage":6553.5,"MPPT_9_Current":6553.5,"MPPT_10_Voltage":6553.5,"MPPT_10_Current":6553.5,"MPPT_11_Voltage":6553.5,"MPPT_11_Current":6553.5,"MPPT_12_Voltage":6553.5,"MPPT_12_Current":6553.5,"Monthly_Power_Yields":2110.2000000000003,"Total_Power_Yields":1.861025799E9,"Negative_Voltage_Ground":-5033.0,"Bus_Voltage":10075.0,"Grid_Frequency_001":5000.0,"PID_work_state":0,"PID_alarm_code":0,"String_1_Current":655.35,"String_2_Current":655.35,"String_3_Current":655.35,"String_4_Current":655.35,"String_5_Current":655.35,"String_6_Current":655.35,"String_7_Current":655.35,"String_8_Current":655.35,"String_9_Current":655.35,"String_10_Current":655.35,"String_11_Current":655.35,"String_12_Current":655.35,"String_13_Current":655.35,"String_14_Current":655.35,"String_15_Current":655.35,"String_16_Current":0.01,"String_17_Current":0.01,"String_18_Current":655.35,"String_19_Current":655.35,"String_20_Current":283.97,"String_21_Current":0.07,"String_22_Current":605.02997,"String_23_Current":100.75,"String_24_Current":50.0,"Year":2022,"Month":11,"Day":15,"Hour":12,"Minute":6,"Second":18,"Start":true,"Stop":false,"Power_limitations_On":true,"Power_limitations_Off":false,"Power_limitations_value":100.0,"Export_power_On":false,"Export_power_Off":false,"Export_power_value":65535,"C_Transformer_output":0,"C_Transformer_range":0,"Current_Transformer":0,"Export_power_percentage":0.0,"Installed_PV_Power":0.0,"Power_Factor_Set":0.0,"Scheduling_to_AAO":0,"Night_SVG_Switch":0,"Reactive_Adjustment_Mode":0,"Reactive_Adjust_Off":false,"Reactive_Adjust_Valid":false,"Reactive_Adjust_Perc":false,"Reactive_Power_Percentage":0.0,"Power_Limit_Adjust":0.0,"Reactive_Power_Adjust":0.0,"PID_Recovery":0,"Anti_PID":0,"Full_Day_PID":0,"Set_Start":false,"Set_Stop":false,"Work_RUN":true}, {"SN":[0,0,0,0,0,0,0,0,0,0],"Device_Type":315,"Nominal_Active_Power":125.0,"Output_Type":2,"Daily_Power_Yield":15.0,"Total_Power_Yield":520522,"Total_Running_Time":15807,"Internal_Temperature":36.4,"Total_Apparent_Power":7331,"Total_DC_Power":7.4430003,"AB_Line_Voltage":603.60004,"BC_Line_Voltage":605.8,"CA_Line_Voltage":603.60004,"Phase_A_Voltage":603.60004,"Phase_B_Voltage":605.8,"Phase_C_Voltage":603.60004,"Phase_A_Current":8.0,"Phase_B_Current":8.0,"Phase_C_Current":8.0,"Total_Active_Power":7.3310003,"Total_Reactive_Power":282,"Power_Factor":99.9,"Grid_frequency_01":50.0,"Work_State_AP1":0,"Alarm_Year":0,"Alarm_Month":0,"Alarm_Day":0,"Alarm_Hour":0,"Alarm_Minute":0,"Alarm_Second":0,"Alarm_Code":0,"Nominal_Reactive":75.0,"Insulation_Resistance":82,"Active_Power_Setpoint":125000,"Reactive_Power_Setpoint":0,"Work_State_AP2":131073,"Meter_Power":-1,"Meter_A_Phase_Power":-1,"Meter_B_Phase_Power":-1,"Meter_C_Phase_power":-1,"Load_Power":-1,"Daily_Export_Energy":4.294967295E8,"Total_Export_Energy":4.294967295E8,"Daily_Import_Energy":4.294967295E8,"Total_Import_Energy":4.294967295E8,"Daily_Energy_Consumption":4.294967295E8,"Total_Energy_Consumption":4.294967295E8,"Daily_Running_Time":218,"Preset_Country":16,"MPPT_1_Voltage":1028.7001,"MPPT_1_Current":7.1,"MPPT_2_Voltage":6553.5,"MPPT_2_Current":6553.5,"MPPT_3_Voltage":6553.5,"MPPT_3_Current":6553.5,"MPPT_4_Voltage":6553.5,"MPPT_4_Current":6553.5,"MPPT_5_Voltage":6553.5,"MPPT_5_Current":6553.5,"MPPT_6_Voltage":6553.5,"MPPT_6_Current":6553.5,"MPPT_7_Voltage":6553.5,"MPPT_7_Current":6553.5,"MPPT_8_Voltage":6553.5,"MPPT_8_Current":6553.5,"MPPT_9_Voltage":6553.5,"MPPT_9_Current":6553.5,"MPPT_10_Voltage":6553.5,"MPPT_10_Current":6553.5,"MPPT_11_Voltage":6553.5,"MPPT_11_Current":6553.5,"MPPT_12_Voltage":6553.5,"MPPT_12_Current":6553.5,"Monthly_Power_Yields":1969.4,"Total_Power_Yields":1.827078223E9,"Negative_Voltage_Ground":-5155.0,"Bus_Voltage":10287.0,"Grid_Frequency_001":5000.0,"PID_work_state":0,"PID_alarm_code":0,"String_1_Current":655.35,"String_2_Current":655.35,"String_3_Current":655.35,"String_4_Current":655.35,"String_5_Current":655.35,"String_6_Current":655.35,"String_7_Current":655.35,"String_8_Current":655.35,"String_9_Current":655.35,"String_10_Current":655.35,"String_11_Current":655.35,"String_12_Current":655.35,"String_13_Current":655.35,"String_14_Current":655.35,"String_15_Current":655.35,"String_16_Current":0.01,"String_17_Current":0.01,"String_18_Current":655.35,"String_19_Current":655.35,"String_20_Current":278.79,"String_21_Current":0.78999996,"String_22_Current":603.81,"String_23_Current":102.869995,"String_24_Current":50.0,"Year":2022,"Month":11,"Day":15,"Hour":10,"Minute":59,"Second":32,"Start":true,"Stop":false,"Power_limitations_On":true,"Power_limitations_Off":false,"Power_limitations_value":100.0,"Export_power_On":false,"Export_power_Off":false,"Export_power_value":65535,"C_Transformer_output":0,"C_Transformer_range":0,"Current_Transformer":0,"Export_power_percentage":0.0,"Installed_PV_Power":0.0,"Power_Factor_Set":0.0,"Scheduling_to_AAO":0,"Night_SVG_Switch":0,"Reactive_Adjustment_Mode":0,"Reactive_Adjust_Off":false,"Reactive_Adjust_Valid":false,"Reactive_Adjust_Perc":false,"Reactive_Power_Percentage":0.0,"Power_Limit_Adjust":0.0,"Reactive_Power_Adjust":0.0,"PID_Recovery":0,"Anti_PID":0,"Full_Day_PID":0,"Set_Start":false,"Set_Stop":false,"Work_RUN":true}, {"SN":[0,0,0,0,0,0,0,0,0,0],"Device_Type":315,"Nominal_Active_Power":125.0,"Output_Type":2,"Daily_Power_Yield":17.4,"Total_Power_Yield":594431,"Total_Running_Time":16161,"Internal_Temperature":37.5,"Total_Apparent_Power":8548,"Total_DC_Power":8.678,"AB_Line_Voltage":604.8,"BC_Line_Voltage":606.8,"CA_Line_Voltage":603.10004,"Phase_A_Voltage":604.8,"Phase_B_Voltage":606.8,"Phase_C_Voltage":603.10004,"Phase_A_Current":9.0,"Phase_B_Current":9.0,"Phase_C_Current":9.0,"Total_Active_Power":8.548,"Total_Reactive_Power":302,"Power_Factor":99.9,"Grid_frequency_01":50.0,"Work_State_AP1":0,"Alarm_Year":0,"Alarm_Month":0,"Alarm_Day":0,"Alarm_Hour":0,"Alarm_Minute":0,"Alarm_Second":0,"Alarm_Code":0,"Nominal_Reactive":75.0,"Insulation_Resistance":81,"Active_Power_Setpoint":125000,"Reactive_Power_Setpoint":0,"Work_State_AP2":131073,"Meter_Power":-1,"Meter_A_Phase_Power":-1,"Meter_B_Phase_Power":-1,"Meter_C_Phase_power":-1,"Load_Power":-1,"Daily_Export_Energy":4.294967295E8,"Total_Export_Energy":4.294967295E8,"Daily_Import_Energy":4.294967295E8,"Total_Import_Energy":4.294967295E8,"Daily_Energy_Consumption":4.294967295E8,"Total_Energy_Consumption":4.294967295E8,"Daily_Running_Time":218,"Preset_Country":16,"MPPT_1_Voltage":1029.6,"MPPT_1_Current":8.400001,"MPPT_2_Voltage":6553.5,"MPPT_2_Current":6553.5,"MPPT_3_Voltage":6553.5,"MPPT_3_Current":6553.5,"MPPT_4_Voltage":6553.5,"MPPT_4_Current":6553.5,"MPPT_5_Voltage":6553.5,"MPPT_5_Current":6553.5,"MPPT_6_Voltage":6553.5,"MPPT_6_Current":6553.5,"MPPT_7_Voltage":6553.5,"MPPT_7_Current":6553.5,"MPPT_8_Voltage":6553.5,"MPPT_8_Current":6553.5,"MPPT_9_Voltage":6553.5,"MPPT_9_Current":6553.5,"MPPT_10_Voltage":6553.5,"MPPT_10_Current":6553.5,"MPPT_11_Voltage":6553.5,"MPPT_11_Current":6553.5,"MPPT_12_Voltage":6553.5,"MPPT_12_Current":6553.5,"Monthly_Power_Yields":2295.7000000000003,"Total_Power_Yields":3.019767898E9,"Negative_Voltage_Ground":-5173.0,"Bus_Voltage":10296.0,"Grid_Frequency_001":5000.0,"PID_work_state":0,"PID_alarm_code":0,"String_1_Current":655.35,"String_2_Current":655.35,"String_3_Current":655.35,"String_4_Current":655.35,"String_5_Current":655.35,"String_6_Current":655.35,"String_7_Current":655.35,"String_8_Current":655.35,"String_9_Current":655.35,"String_10_Current":655.35,"String_11_Current":655.35,"String_12_Current":655.35,"String_13_Current":655.35,"String_14_Current":655.35,"String_15_Current":655.35,"String_16_Current":0.01,"String_17_Current":0.01,"String_18_Current":655.35,"String_19_Current":655.35,"String_20_Current":460.78,"String_21_Current":0.9,"String_22_Current":603.63,"String_23_Current":102.96,"String_24_Current":50.0,"Year":2022,"Month":11,"Day":15,"Hour":11,"Minute":2,"Second":47,"Start":true,"Stop":false,"Power_limitations_On":true,"Power_limitations_Off":false,"Power_limitations_value":100.0,"Export_power_On":false,"Export_power_Off":false,"Export_power_value":65535,"C_Transformer_output":0,"C_Transformer_range":0,"Current_Transformer":0,"Export_power_percentage":0.0,"Installed_PV_Power":0.0,"Power_Factor_Set":0.0,"Scheduling_to_AAO":0,"Night_SVG_Switch":0,"Reactive_Adjustment_Mode":0,"Reactive_Adjust_Off":false,"Reactive_Adjust_Valid":false,"Reactive_Adjust_Perc":false,"Reactive_Power_Percentage":0.0,"Power_Limit_Adjust":0.0,"Reactive_Power_Adjust":0.0,"PID_Recovery":0,"Anti_PID":0,"Full_Day_PID":0,"Set_Start":false,"Set_Stop":false,"Work_RUN":true}, {"SN":[0,0,0,0,0,0,0,0,0,0],"Device_Type":315,"Nominal_Active_Power":125.0,"Output_Type":2,"Daily_Power_Yield":15.0,"Total_Power_Yield":535212,"Total_Running_Time":15809,"Internal_Temperature":37.7,"Total_Apparent_Power":7210,"Total_DC_Power":7.32,"AB_Line_Voltage":604.10004,"BC_Line_Voltage":604.5,"CA_Line_Voltage":603.0,"Phase_A_Voltage":604.10004,"Phase_B_Voltage":604.5,"Phase_C_Voltage":603.0,"Phase_A_Current":7.9,"Phase_B_Current":7.9,"Phase_C_Current":8.0,"Total_Active_Power":7.2100005,"Total_Reactive_Power":264,"Power_Factor":100.0,"Grid_frequency_01":50.0,"Work_State_AP1":0,"Alarm_Year":0,"Alarm_Month":0,"Alarm_Day":0,"Alarm_Hour":0,"Alarm_Minute":0,"Alarm_Second":0,"Alarm_Code":0,"Nominal_Reactive":75.0,"Insulation_Resistance":73,"Active_Power_Setpoint":125000,"Reactive_Power_Setpoint":0,"Work_State_AP2":131073,"Meter_Power":-1,"Meter_A_Phase_Power":-1,"Meter_B_Phase_Power":-1,"Meter_C_Phase_power":-1,"Load_Power":-1,"Daily_Export_Energy":4.294967295E8,"Total_Export_Energy":4.294967295E8,"Daily_Import_Energy":4.294967295E8,"Total_Import_Energy":4.294967295E8,"Daily_Energy_Consumption":4.294967295E8,"Total_Energy_Consumption":4.294967295E8,"Daily_Running_Time":213,"Preset_Country":16,"MPPT_1_Voltage":1017.9,"MPPT_1_Current":7.2000003,"MPPT_2_Voltage":6553.5,"MPPT_2_Current":6553.5,"MPPT_3_Voltage":6553.5,"MPPT_3_Current":6553.5,"MPPT_4_Voltage":6553.5,"MPPT_4_Current":6553.5,"MPPT_5_Voltage":6553.5,"MPPT_5_Current":6553.5,"MPPT_6_Voltage":6553.5,"MPPT_6_Current":6553.5,"MPPT_7_Voltage":6553.5,"MPPT_7_Current":6553.5,"MPPT_8_Voltage":6553.5,"MPPT_8_Current":6553.5,"MPPT_9_Voltage":6553.5,"MPPT_9_Current":6553.5,"MPPT_10_Voltage":6553.5,"MPPT_10_Current":6553.5,"MPPT_11_Voltage":6553.5,"MPPT_11_Current":6553.5,"MPPT_12_Voltage":6553.5,"MPPT_12_Current":6553.5,"Monthly_Power_Yields":2023.5,"Total_Power_Yields":2.864644177E9,"Negative_Voltage_Ground":-5086.0,"Bus_Voltage":10179.0,"Grid_Frequency_001":5000.0,"PID_work_state":0,"PID_alarm_code":0,"String_1_Current":655.35,"String_2_Current":655.35,"String_3_Current":655.35,"String_4_Current":655.35,"String_5_Current":655.35,"String_6_Current":655.35,"String_7_Current":655.35,"String_8_Current":655.35,"String_9_Current":655.35,"String_10_Current":655.35,"String_11_Current":655.35,"String_12_Current":655.35,"String_13_Current":655.35,"String_14_Current":655.35,"String_15_Current":655.35,"String_16_Current":0.01,"String_17_Current":0.01,"String_18_Current":655.35,"String_19_Current":655.35,"String_20_Current":437.11,"String_21_Current":0.81,"String_22_Current":604.5,"String_23_Current":101.79,"String_24_Current":50.0,"Year":2022,"Month":11,"Day":15,"Hour":11,"Minute":0,"Second":46,"Start":true,"Stop":false,"Power_limitations_On":true,"Power_limitations_Off":false,"Power_limitations_value":100.0,"Export_power_On":false,"Export_power_Off":false,"Export_power_value":65535,"C_Transformer_output":0,"C_Transformer_range":0,"Current_Transformer":0,"Export_power_percentage":0.0,"Installed_PV_Power":0.0,"Power_Factor_Set":0.0,"Scheduling_to_AAO":0,"Night_SVG_Switch":0,"Reactive_Adjustment_Mode":0,"Reactive_Adjust_Off":false,"Reactive_Adjust_Valid":false,"Reactive_Adjust_Perc":false,"Reactive_Power_Percentage":0.0,"Power_Limit_Adjust":0.0,"Reactive_Power_Adjust":0.0,"PID_Recovery":0,"Anti_PID":0,"Full_Day_PID":0,"Set_Start":false,"Set_Stop":false,"Work_RUN":true}, {"SN":[0,0,0,0,0,0,0,0,0,0],"Device_Type":315,"Nominal_Active_Power":125.0,"Output_Type":2,"Daily_Power_Yield":16.2,"Total_Power_Yield":561457,"Total_Running_Time":16127,"Internal_Temperature":37.4,"Total_Apparent_Power":7845,"Total_DC_Power":7.964,"AB_Line_Voltage":604.4,"BC_Line_Voltage":606.4,"CA_Line_Voltage":602.3,"Phase_A_Voltage":604.4,"Phase_B_Voltage":606.4,"Phase_C_Voltage":602.3,"Phase_A_Current":8.400001,"Phase_B_Current":8.400001,"Phase_C_Current":8.5,"Total_Active_Power":7.8450003,"Total_Reactive_Power":288,"Power_Factor":99.9,"Grid_frequency_01":50.0,"Work_State_AP1":0,"Alarm_Year":0,"Alarm_Month":0,"Alarm_Day":0,"Alarm_Hour":0,"Alarm_Minute":0,"Alarm_Second":0,"Alarm_Code":0,"Nominal_Reactive":75.0,"Insulation_Resistance":86,"Active_Power_Setpoint":125000,"Reactive_Power_Setpoint":0,"Work_State_AP2":131073,"Meter_Power":-1,"Meter_A_Phase_Power":-1,"Meter_B_Phase_Power":-1,"Meter_C_Phase_power":-1,"Load_Power":-1,"Daily_Export_Energy":4.294967295E8,"Total_Export_Energy":4.294967295E8,"Daily_Import_Energy":4.294967295E8,"Total_Import_Energy":4.294967295E8,"Daily_Energy_Consumption":4.294967295E8,"Total_Energy_Consumption":4.294967295E8,"Daily_Running_Time":216,"Preset_Country":16,"MPPT_1_Voltage":1029.2001,"MPPT_1_Current":7.8,"MPPT_2_Voltage":6553.5,"MPPT_2_Current":6553.5,"MPPT_3_Voltage":6553.5,"MPPT_3_Current":6553.5,"MPPT_4_Voltage":6553.5,"MPPT_4_Current":6553.5,"MPPT_5_Voltage":6553.5,"MPPT_5_Current":6553.5,"MPPT_6_Voltage":6553.5,"MPPT_6_Current":6553.5,"MPPT_7_Voltage":6553.5,"MPPT_7_Current":6553.5,"MPPT_8_Voltage":6553.5,"MPPT_8_Current":6553.5,"MPPT_9_Voltage":6553.5,"MPPT_9_Current":6553.5,"MPPT_10_Voltage":6553.5,"MPPT_10_Current":6553.5,"MPPT_11_Voltage":6553.5,"MPPT_11_Current":6553.5,"MPPT_12_Voltage":6553.5,"MPPT_12_Current":6553.5,"Monthly_Power_Yields":2234.3,"Total_Power_Yields":2.884698197E9,"Negative_Voltage_Ground":-5165.0,"Bus_Voltage":10292.0,"Grid_Frequency_001":5000.0,"PID_work_state":0,"PID_alarm_code":0,"String_1_Current":655.35,"String_2_Current":655.35,"String_3_Current":655.35,"String_4_Current":655.35,"String_5_Current":655.35,"String_6_Current":655.35,"String_7_Current":655.35,"String_8_Current":655.35,"String_9_Current":655.35,"String_10_Current":655.35,"String_11_Current":655.35,"String_12_Current":655.35,"String_13_Current":655.35,"String_14_Current":655.35,"String_15_Current":655.35,"String_16_Current":0.01,"String_17_Current":0.01,"String_18_Current":655.35,"String_19_Current":655.35,"String_20_Current":440.16998,"String_21_Current":0.84999996,"String_22_Current":603.70996,"String_23_Current":102.92,"String_24_Current":50.0,"Year":2022,"Month":11,"Day":15,"Hour":11,"Minute":4,"Second":21,"Start":true,"Stop":false,"Power_limitations_On":true,"Power_limitations_Off":false,"Power_limitations_value":100.0,"Export_power_On":false,"Export_power_Off":false,"Export_power_value":65535,"C_Transformer_output":0,"C_Transformer_range":0,"Current_Transformer":0,"Export_power_percentage":0.0,"Installed_PV_Power":0.0,"Power_Factor_Set":0.0,"Scheduling_to_AAO":0,"Night_SVG_Switch":0,"Reactive_Adjustment_Mode":0,"Reactive_Adjust_Off":false,"Reactive_Adjust_Valid":false,"Reactive_Adjust_Perc":false,"Reactive_Power_Percentage":0.0,"Power_Limit_Adjust":0.0,"Reactive_Power_Adjust":0.0,"PID_Recovery":0,"Anti_PID":0,"Full_Day_PID":0,"Set_Start":false,"Set_Stop":false,"Work_RUN":true}, {"SN":[0,0,0,0,0,0,0,0,0,0],"Device_Type":315,"Nominal_Active_Power":125.0,"Output_Type":2,"Daily_Power_Yield":16.9,"Total_Power_Yield":530068,"Total_Running_Time":15452,"Internal_Temperature":36.0,"Total_Apparent_Power":8104,"Total_DC_Power":8.224,"AB_Line_Voltage":604.4,"BC_Line_Voltage":606.60004,"CA_Line_Voltage":604.10004,"Phase_A_Voltage":604.4,"Phase_B_Voltage":606.60004,"Phase_C_Voltage":604.10004,"Phase_A_Current":8.400001,"Phase_B_Current":8.5,"Phase_C_Current":8.6,"Total_Active_Power":8.101001,"Total_Reactive_Power":280,"Power_Factor":99.9,"Grid_frequency_01":50.0,"Work_State_AP1":0,"Alarm_Year":0,"Alarm_Month":0,"Alarm_Day":0,"Alarm_Hour":0,"Alarm_Minute":0,"Alarm_Second":0,"Alarm_Code":0,"Nominal_Reactive":75.0,"Insulation_Resistance":83,"Active_Power_Setpoint":125000,"Reactive_Power_Setpoint":0,"Work_State_AP2":131073,"Meter_Power":-1,"Meter_A_Phase_Power":-1,"Meter_B_Phase_Power":-1,"Meter_C_Phase_power":-1,"Load_Power":-1,"Daily_Export_Energy":4.294967295E8,"Total_Export_Energy":4.294967295E8,"Daily_Import_Energy":4.294967295E8,"Total_Import_Energy":4.294967295E8,"Daily_Energy_Consumption":4.294967295E8,"Total_Energy_Consumption":4.294967295E8,"Daily_Running_Time":219,"Preset_Country":16,"MPPT_1_Voltage":1032.5,"MPPT_1_Current":7.9,"MPPT_2_Voltage":6553.5,"MPPT_2_Current":6553.5,"MPPT_3_Voltage":6553.5,"MPPT_3_Current":6553.5,"MPPT_4_Voltage":6553.5,"MPPT_4_Current":6553.5,"MPPT_5_Voltage":6553.5,"MPPT_5_Current":6553.5,"MPPT_6_Voltage":6553.5,"MPPT_6_Current":6553.5,"MPPT_7_Voltage":6553.5,"MPPT_7_Current":6553.5,"MPPT_8_Voltage":6553.5,"MPPT_8_Current":6553.5,"MPPT_9_Voltage":6553.5,"MPPT_9_Current":6553.5,"MPPT_10_Voltage":6553.5,"MPPT_10_Current":6553.5,"MPPT_11_Voltage":6553.5,"MPPT_11_Current":6553.5,"MPPT_12_Voltage":6553.5,"MPPT_12_Current":6553.5,"Monthly_Power_Yields":2269.3,"Total_Power_Yields":3.788177488E9,"Negative_Voltage_Ground":-5172.0,"Bus_Voltage":10335.0,"Grid_Frequency_001":4999.0,"PID_work_state":0,"PID_alarm_code":0,"String_1_Current":655.35,"String_2_Current":655.35,"String_3_Current":655.35,"String_4_Current":655.35,"String_5_Current":655.35,"String_6_Current":655.35,"String_7_Current":655.35,"String_8_Current":655.35,"String_9_Current":655.35,"String_10_Current":655.35,"String_11_Current":655.35,"String_12_Current":655.35,"String_13_Current":655.35,"String_14_Current":655.35,"String_15_Current":655.35,"String_16_Current":0.01,"String_17_Current":0.01,"String_18_Current":655.35,"String_19_Current":655.35,"String_20_Current":578.01996,"String_21_Current":0.79999995,"String_22_Current":603.76,"String_23_Current":103.25,"String_24_Current":50.0,"Year":2022,"Month":11,"Day":15,"Hour":11,"Minute":1,"Second":10,"Start":true,"Stop":false,"Power_limitations_On":true,"Power_limitations_Off":false,"Power_limitations_value":100.0,"Export_power_On":false,"Export_power_Off":false,"Export_power_value":65535,"C_Transformer_output":0,"C_Transformer_range":0,"Current_Transformer":0,"Export_power_percentage":0.0,"Installed_PV_Power":0.0,"Power_Factor_Set":0.0,"Scheduling_to_AAO":0,"Night_SVG_Switch":0,"Reactive_Adjustment_Mode":0,"Reactive_Adjust_Off":false,"Reactive_Adjust_Valid":false,"Reactive_Adjust_Perc":false,"Reactive_Power_Percentage":0.0,"Power_Limit_Adjust":0.0,"Reactive_Power_Adjust":0.0,"PID_Recovery":0,"Anti_PID":0,"Full_Day_PID":0,"Set_Start":false,"Set_Stop":false,"Work_RUN":true}, {"SN":[0,0,0,0,0,0,0,0,0,0],"Device_Type":315,"Nominal_Active_Power":125.0,"Output_Type":2,"Daily_Power_Yield":16.5,"Total_Power_Yield":554065,"Total_Running_Time":16247,"Internal_Temperature":35.2,"Total_Apparent_Power":7938,"Total_DC_Power":8.059,"AB_Line_Voltage":604.2,"BC_Line_Voltage":606.3,"CA_Line_Voltage":604.2,"Phase_A_Voltage":604.2,"Phase_B_Voltage":606.3,"Phase_C_Voltage":604.2,"Phase_A_Current":8.6,"Phase_B_Current":8.6,"Phase_C_Current":8.6,"Total_Active_Power":7.938,"Total_Reactive_Power":282,"Power_Factor":99.9,"Grid_frequency_01":50.0,"Work_State_AP1":0,"Alarm_Year":0,"Alarm_Month":0,"Alarm_Day":0,"Alarm_Hour":0,"Alarm_Minute":0,"Alarm_Second":0,"Alarm_Code":0,"Nominal_Reactive":75.0,"Insulation_Resistance":84,"Active_Power_Setpoint":125000,"Reactive_Power_Setpoint":0,"Work_State_AP2":131073,"Meter_Power":-1,"Meter_A_Phase_Power":-1,"Meter_B_Phase_Power":-1,"Meter_C_Phase_power":-1,"Load_Power":-1,"Daily_Export_Energy":4.294967295E8,"Total_Export_Energy":4.294967295E8,"Daily_Import_Energy":4.294967295E8,"Total_Import_Energy":4.294967295E8,"Daily_Energy_Consumption":4.294967295E8,"Total_Energy_Consumption":4.294967295E8,"Daily_Running_Time":219,"Preset_Country":16,"MPPT_1_Voltage":1010.0,"MPPT_1_Current":8.0,"MPPT_2_Voltage":6553.5,"MPPT_2_Current":6553.5,"MPPT_3_Voltage":6553.5,"MPPT_3_Current":6553.5,"MPPT_4_Voltage":6553.5,"MPPT_4_Current":6553.5,"MPPT_5_Voltage":6553.5,"MPPT_5_Current":6553.5,"MPPT_6_Voltage":6553.5,"MPPT_6_Current":6553.5,"MPPT_7_Voltage":6553.5,"MPPT_7_Current":6553.5,"MPPT_8_Voltage":6553.5,"MPPT_8_Current":6553.5,"MPPT_9_Voltage":6553.5,"MPPT_9_Current":6553.5,"MPPT_10_Voltage":6553.5,"MPPT_10_Current":6553.5,"MPPT_11_Voltage":6553.5,"MPPT_11_Current":6553.5,"MPPT_12_Voltage":6553.5,"MPPT_12_Current":6553.5,"Monthly_Power_Yields":2222.7000000000003,"Total_Power_Yields":2.335375444E9,"Negative_Voltage_Ground":-5054.0,"Bus_Voltage":10100.0,"Grid_Frequency_001":5000.0,"PID_work_state":0,"PID_alarm_code":0,"String_1_Current":655.35,"String_2_Current":655.35,"String_3_Current":655.35,"String_4_Current":655.35,"String_5_Current":655.35,"String_6_Current":655.35,"String_7_Current":655.35,"String_8_Current":655.35,"String_9_Current":655.35,"String_10_Current":655.35,"String_11_Current":655.35,"String_12_Current":655.35,"String_13_Current":655.35,"String_14_Current":655.35,"String_15_Current":655.35,"String_16_Current":0.01,"String_17_Current":0.01,"String_18_Current":655.35,"String_19_Current":655.35,"String_20_Current":356.35,"String_21_Current":0.84,"String_22_Current":604.82,"String_23_Current":101.0,"String_24_Current":50.0,"Year":2022,"Month":11,"Day":15,"Hour":10,"Minute":57,"Second":41,"Start":true,"Stop":false,"Power_limitations_On":true,"Power_limitations_Off":false,"Power_limitations_value":100.0,"Export_power_On":false,"Export_power_Off":false,"Export_power_value":65535,"C_Transformer_output":0,"C_Transformer_range":0,"Current_Transformer":0,"Export_power_percentage":0.0,"Installed_PV_Power":0.0,"Power_Factor_Set":0.0,"Scheduling_to_AAO":0,"Night_SVG_Switch":0,"Reactive_Adjustment_Mode":0,"Reactive_Adjust_Off":false,"Reactive_Adjust_Valid":false,"Reactive_Adjust_Perc":false,"Reactive_Power_Percentage":0.0,"Power_Limit_Adjust":0.0,"Reactive_Power_Adjust":0.0,"PID_Recovery":0,"Anti_PID":0,"Full_Day_PID":0,"Set_Start":false,"Set_Stop":false,"Work_RUN":true}]
Uncertain value appears after reconstruction, I am using UDT. I recreated this situation without UDT and it works without probem. Why such problems when I do it using the method I indicated.
Below is the version that works without a problem.
You can see that where it does not work the function is grayed out. From what I have determined myself it does not interpret {TagName} correctly.
Here you can see that the nested internal JSON function works but using {TagName} Uncertain appears.
Here a still version when I enter it manually.
These {TagName} bindings are a very useful option allowing to which I can copy one function for several hundred tags without nameing addressing.
Greetings
Problem solved. It's a matter of using expression editor instead of binding editor. So my question is what is the difference between both? And why doesn't it work in bindings - it works in a limited way without being able to use {TagName}?
I believe the 'binding' executes at a somewhat different time, it's a sort of "precalculation" before the rest of the tag starts running. An expression is always a true runtime calculation, so it's not subject to the same limitations.
As an aside, I think you should be able to use a single jsonGet to retrieve the information you want; using two is making things less efficient.
It's JSON inside JSON so I haven't found another way to extract this data from the tag
The second argument to jsonGet is a JSON path; it doesn't have to be a single JSON key. So you could pass e.g. jsonGet(json, "[1]AB_Line_Voltage") and it should work. You just need to dynamically assemble the full string.
I tested it and it actually works, excellent. Thank you for your advice!
