Hello,
Is it bad practise to use "Edge Nodes/" in the topic of a MQTT transmitter that does not have sparkplug B? Meaning that a sensor transmitting on "regular" mqtt ends up in the MQTT engine "Edge Nodes" folder together with the sparkplug B sensors.
We are doing it right now, and it looks to work fine besides the million JsonPayloadHandler errors:
com.fasterxml.jackson.core.JsonParseException: Unrecognized token 'D8': was expecting (JSON String, Number, Array, Object or token 'null', 'true' or 'false') at [Source: (byte[])"D8:3B:DA:C4:03:C8"; line: 1, column: 4]
at com.fasterxml.jackson.core.JsonParser._constructError(JsonParser.java:2391)
at com.fasterxml.jackson.core.base.ParserMinimalBase._reportError(ParserMinimalBase.java:745)
at com.fasterxml.jackson.core.json.UTF8StreamJsonParser._reportInvalidToken(UTF8StreamJsonParser.java:3634)
at com.fasterxml.jackson.core.json.UTF8StreamJsonParser._handleUnexpectedValue(UTF8StreamJsonParser.java:2734)
at com.fasterxml.jackson.core.json.UTF8StreamJsonParser._nextTokenNotInObject(UTF8StreamJsonParser.java:902)
at com.fasterxml.jackson.core.json.UTF8StreamJsonParser.nextToken(UTF8StreamJsonParser.java:794)
at com.fasterxml.jackson.databind.ObjectMapper._initForReading(ObjectMapper.java:4761)
at com.fasterxml.jackson.databind.ObjectMapper._readMapAndClose(ObjectMapper.java:4667)
at com.fasterxml.jackson.databind.ObjectMapper.readValue(ObjectMapper.java:3707)
at com.cirruslink.mqtt.engine.gateway.json.JsonPayloadHandler.handlePayload(JsonPayloadHandler.java:148)
at com.cirruslink.mqtt.engine.gateway.EngineCallback.lambda$messageArrived$0(EngineCallback.java:260)
