Using html5/JavaScript component in ignitio
Hi
Is possible in import html5/JavaScript component in ignition?
there are many free gorgeous component on net like justguage.com chartjs.com
which make HMI beautiful.
I used to work with indusoft and there is component which import html5 component in HMI.
Best regards
the www.justguage.com, www.chartjs.com sites don'y seem to exist!
As on date, Ignition client is Java based. We are expecting that they will release a ReactJS client called "Perspective" along with Ignition V8. Until then, you have to build your own JS client. You can check this link.
I think this is the correct link.
