I am hoping to get a nailed on answer if its is possible to open ignition on a client machine without Java if the parent machine has got java installed with any version of 7.9 or was this only added to the ignition 8
If you use the Native Client Launcher instead of the JNLP files you can launch a Vision Client without Java installed because the NCL includes its own copy.
Im getting this error when i try using the native client launcher
Show some logical troubleshooting!
- Did you confirm that the gateway is running?
- What result did you get when you pinged the gateway from the client PC?
- What result did you get when you browsed to
http://<gatewayIp>:8088from the client PC?
The gateway is running as its on my PC Infront of me and trying to access it from another beside me i ca ping the Ip address both ways and i can open the web browser but when i go to use the native launcher and type my project in it comes up available and i click on it it starts to download the packets to open the project and when it gets to the 71/71 it crashes and shows that error instead of the usual open of the project
That sounds like some anti-virus interfering.
