Using Ignition with OpenJDK (Windows)?
Currently, the Native Launcher can’t detect OpenJDK installs, so for now you’ll have to do a workaround. Copy all of the folders from the root of your OpenJDK install (bin, lib, etc) and place them in a jre folder that is sitting in the same directory as your client launcher executable. Not an ideal solution, but it should get your clients/designers up and running.
