What is the simplest way to connect to an OSI PI server and get the data from it? Looking to use the PI Historian data for Reporting within Ignition.
I am involved with a PI project at the moment.
If you just want historical time series data from PI, you need the Ignition OPC-DA module .
If you want to query data from PI, you need to create a custom JDBC driver in Ignition and have PI side modules installed to create virtual data tables that can be queried
