Using jsonGet to access individual elements of json arrays
Using the Ignition 8 jsonGet function, is it possible to directly specify a json array location in the path parameter?
Using the VisualStudio 2019 RESTful API example program output as an example:
[{“date”:“2020-01-18T09:34:52.4573681-08:00”,“temperatureC”:20,“temperatureF”:67,“summary”:“Warm”}]
I am not sure how to access the only element (0) of this json array using jsonGet directly.
Try "[0]" as the path.
