Is it possible to still have the ability to use embedded pdfs(in windows via the activeX module), while running linux as an IA client?
[del]Edit: This has been posted in the wrong forum, I meant for General Discussion[/del] (Topic Moved)
ActiveX and Linux do not play together, unfortunately. ActiveX is strictly a Windows technology. You can use our pure-Java PDF viewer that comes with the reporting module, but it has deficiencies (only able to reliably view some PDFs).
Is there coming improvements to PDF Viewer for non-Windows platforms, so that it would be possible to show more pdfs than in current version?
There has been some talk of licensing a higher quality 100% java pdf renderer, but nothing concrete as of yet.
