Hi there,
Is there a script command to create a template instance?
I’m dealing with a project to create input boxes based on the result I query from other system.
For example, there are 4 items returned from the query and each item has different number of inputs required. Something like
My idea is to create a template with dropdown list and text input components. Each template is for each item and dropdown list will be a number of inputs required. User will be select number and enter value in the text input components then store as a dataset or dictionary type.
I want to be able to create template instance from script based on the number of items returned.
If there are any other better ways to do, please suggest.
The recommended approach is to use the Template Canvas or Template Repeater to dynamically create template instances. Here’s a tutorial on the Template Canvas: nickmudge.info/post/ignitions-te … at-runtime
I would like to recreate the Template Canvas Customizer in a client window to give users the ability to build dashboards on their own without the designer.
I think I can do just about everything to populate the Templates dataset except for providing the drop-down of available templates and then expose the selected template’s parameters. I know I could build database tables pre-populated with template names and parameters but was hoping to just use whatever the customizer is using.
You’d need to do something in addition to this for the UDT association but this will list templates from the designer. I think I got it from Nick originally but don’t see that post anymore. This is on the mousePressed event of a drop-down:
[code]def getProjectTemplates(event):
import system
comp = event.source
if system.util.getSystemFlags() & system.util.DESIGNER_FLAG:
from com.inductiveautomation.ignition.designer import IgnitionDesigner
while not isinstance(comp,IgnitionDesigner):
comp = comp.parent
context = comp.getContext()
else:
from com.inductiveautomation.factorypmi.application.runtime import ClientPanel
while not isinstance(comp,ClientPanel):
comp = comp.parent
context = comp.getClientContext()
project = context.getProject()
templates = project.getResourcesOfType(“fpmi”,“component-template”)
templatePaths = [project.getFolderPath(template.getResourceId()) for template in templates]
return templatePaths
#Get templates from Gateway
l = []
templatePaths = getProjectTemplates(event)
for path in templatePaths:
if path.startswith(“Dashboard/”): #Use specific folder to hold all Dashboard-related templates
l.append([path])
data = system.dataset.toDataSet([“Value”], l)
event.source.data = data[/code]
