Can I try using SECS/GEM module in the Maker edition ?
I found the message: "Not eligible for use with Ignition Maker Edition" after downloading and installing the module to Ignition 8.1.39.
If not, how do I try using the SECS/GEM module ?
Use Standard Edition and reset trial every 2 hours.
Thank you!
But, how do I get the standard edition ?
You are selecting the version after a clean install of Ignition during commissioning.
Installing and Upgrading Ignition | Ignition User Manual (inductiveautomation.com)
