Hello,
Looking for a little guidance on the following.
If I pass parameters for say Actor filter, what value would I need to set it to in order to return all actors vs a single actor.
Thanks,
Frank
I think through some testing I have arrived at one solution. As long as the parameter values are blank it returns everything. Unless there is a better way to do this I will stick with it.
Leaving blank is fine, or you can use a SQL wildcard - %; ultimately, the actor filter you provide makes its way into a SQL LIKE clause in the query given to the database:
https://www.w3schools.com/sql/sql_like.asp
