Using "Store and Forward" mechanism from a module (driver)
I have a OPC-UA driver that creates an OPC-UA tag tree, but also writes some data to a database. Now I am doing the writing through the SRConnection.runPrepQuery … I wonder if its possible to use the Ignition “Store and Forward” functionality instead. If it’s possible, a short hint would be highly appreciated.
Thanks!
You need to use the history manager to store information through the store and forward. First you need to create a class that implements DatasourceData:
[code]public class QuerySFData implements DatasourceData {
private static final long serialVersionUID = 1L;
    String query;
    String datasource;
    Object[] values;
    public QuerySFData(String query, String datasource) {
            this(query, null, datasource);
    public QuerySFData(String query, Object[] values, String datasource) {
            this.query = query;
            this.values = values;
            this.datasource = datasource;
    @Override
    public int getDataCount() {
            return 1;
    @Override
    public HistoryFlavor getFlavor() {
            return DatasourceData.FLAVOR;
    @Override
    public String getLoggerName() {
            return "Client Store & Forward";
    @Override
    public String getSignature() {
            return "SFQuery: " + datasource + " - " + query;
    @Override
    public void storeToConnection(SRConnection conn) throws Exception {
            if (values != null) {
                    conn.runPrepUpdate(query, values);
            } else {
                    conn.runUpdateQuery(query);
}[/code]
Then you just call:
context.getHistoryManager().storeHistory("YourDataSourceName", new QuerySFData(query, values, datasource));
