Using Stored Procedure In Reporting
I am currently utilizing some stored procedures to populate tables within the Ignition Designer.
I want to utilize the result sets in a table and pie object in the Report Viewer but it looks to me like the Script option data source does not support this in the function that’s provided.
How would I go about returning a data set from SQL Server into the Report Viewer?
You can just put the name of a stored procedure inside the Basic SQL Query datasource type.
I just tested it with a single parameter SP.
NameOfMyStoredProcedure MyParameter
What does the syntax look like? I had been using something like this:
call = system.db.createSProcCall(“sproc”)
call.registerInParam(“p1”, system.db.TIMESTAMP, var1)
call.registerInParam(“p2”, system.db.TIMESTAMP, var2)
system.db.execSProcCall(call)
data = call.getResultSet()
Literally MyStoredProcedureName ‘MyStringParameter’
It works - so simple it went right over my head
Good morning,
if I have more parameters for store procedure, how can I send them?
I’m try to do in this mode :
spReportAnalisiFermate {pDateStart} {pDateEnd} {pGplant_AS} {pMachine_AS} {plang} {pCod_MacroStp_AS} {pZone_Prod_AS}
in this mode only errors
Separate them with commas
spReportAnalisiFermate {pDateStart},{pDateEnd},{pGplant_AS},{pMachine_AS},{plang},{pCod_MacroStp_AS},{pZone_Prod_AS}
i get this error...
Change your Query Type to Basic SQL Query
I have try to put Basic SQL Query, now error is go away but a new error is on.
How i can debug these?
Post the new error and a screenshot of your report data tab
