In Ignition 7.9,
I have a historical transaction group with opc tags from a control logix plc. Three of those tags are strings, the other 10 or so are Int4.
When I drag the opc items over to the group item window, the string items have two components; the length and the string value. When I drag over just the string values for those three items, I then get three items all called “STRING” which I then of course map to different columns in the table.
BUT, Ignition gives me a warning in the Events box that says “WARN The following names are defined multiple times in the group: [STRING]. Item references may not work correctly…”
Is there a different approach I should be taking with these strings, or is this a warning that I can just ignore in this case? The group seems to run fine…
Thanks.
