Using stylesheet.css to make an icon blink
I am using the stylesheet.css to manage my styles, and I want to make an alarm icon blink in the smooth form that the style below allows for. Any ideas how I can make this work using the style sheet? I am using 8.1.45 and am planning to upgrade to 8.3.2 here next week.
@keyframes psc-blinker-anim {
     0%  { fill: #FF0000; }
     100% { fill: #D0D0D0; }
.psc-blinker svg path {
     animation-name: psc-blinker-anim;
     animation-duration: 1s;
     animation-iteration-count: infinite;
     animation-direction: alternate;
     animation-timing-function: linear;
  • Update to this, when I go from design to runtime it quits working. I have found that the CSS animation is not being applied at runtime, however it would still work on the designer
Check the silly stuff. Use the browser's Developer Tools (F12), find the CSS file and check that your animation class is actually in there. If not, then Ctrl-F5 should reload everything from the site and update the cache.
Yup already gone through that routine, the CSS does not show the animation class in the Dev tools
When looking through the computed tab this is what the animations look like, i am at this point selecting the svg of the Icon. It shows that the class = “pcs-blinker”, however it does not show the animation style as seen below
accent-color auto
align-content normal
align-items normal
align-self auto
alignment-baseline auto
all
animation-composition replace
animation-delay 0s
animation-direction normal
animation-duration 0s
animation-fill-mode none
animation-iteration-count 1
animation-name none
animation-play-state running
animation-range-end normal
animation-range-start normal
animation-timeline auto
animation-timing-function ease
app-region none
appearance none
aspect-ratio auto
backdrop-filter none
backface-visibility visible
background-attachment scroll
background-blend-mode normal
background-clip border-box
background-color rgba(0, 0, 0, 0)
background-image none
background-origin padding-box
background-position-x 0%
background-position-y 0%
background-repeat repeat
background-size auto
baseline-shift 0px
baseline-source auto
block-size 50px
border-block-end-color rgb(50, 50, 50)
It's not quite clear where you looked for the style. I added an easily identifiable comment into my Advanced Stylesheet, saved, and launched the project.
In Developer Tools → Network → CSS → style.css.
The comment showed up in there along with some other stuff that is in the Advanced Stylesheet and more stuff that isn't.
i found the style sheet, however what I was sending is from the </> Elements tab
Take a look in the styles tab next to computed. Use that to confirm that the style information is being applied and isn't being subsequently overwritten by some other conflicting style.
I think the issue stems from this line here:
In the browser session, the <svg> element is what has the .psc-blinker class. I can’t speak for why it’s working in the Designer, but after removing the “svg” piece of the selector (and I suspect you’d see the same results by declaring an <svg> with the given class, a la “svg.psc-blinker”) I was able to see the animation in the browser session.
So try this:
.psc-blinker path {
This worked for me thank you!
