Hey guys, I use different formats of expression tags(time intervals) in my SQL WHERE clause. I get this error when I open a window that uses a query:
SELECT
t_stamp,
column1 AS 'part1',
column2 AS 'part2'
FROM
table
WHERE
t_stamp BETWEEN 'date1' AND 'date2';
When I open a window that has this query in the background I get an error :
Exception: Error running query:
SQLQuery(query=SELECT
t_stamp,
column1 AS 'part1',
column2 AS 'part2
FROM
table
WHERE
t_stamp BETWEEN '-1' AND '-1';
, database=Database)@3600000ms
On: Main Menu.Root Container.Chart.Data
caused by GatewayException: Conversion failed when converting date and/or time from character string.
caused by SQLServerException: Conversion failed when converting date and/or time from character string.
Ignition v7.8.2 (b2016030813)
Java: Oracle Corporation 1.8.0_91
Now I did some research into this and few places suggested it might have something to do with the format of my time stamp. right now I use the format yyyy-MM-dd hh:mm:ss. I’ve tried both string type and date time type but my issue is I can’t use string for both tags because in one do some date arithmetic and it wont let you do that from a string data type tag and have to use a date time format.
I guess what I’m trying to get to is if you guys use tags for your WHERE clause, what kind of format do you use? Thanks for the help in advance!
in scripting I use the following to set date strings to valid date formats
from java.text import SimpleDateFormat
inputFormat=SimpleDateFormat("yyyy-MM-dd HH:mm:ss") # Must match the format of the input string
outputFormat=SimpleDateFormat("yyyy-MM-dd HH:mm:ss") # The format you want to convert to
dateIn=event.source.selectedStringValue
processedDateIn=SimpleDateFormat.parse(inputFormat,dateIn) # Convert Input String to Java Date
event.source.parent.getComponent('Power Table').SDate=processedDateIn
event.source.parent.getComponent('Power Table').EDate=system.date.addMinutes(processedDateIn,7)
Quick Update:
I tried messing with it and instead of BETWEEN I used t_stamo > and t_stamp < and didn’t get the error, oh and also changed my format to yyyy-MM-dd HH:mm:ss from yyyy-MM-dd hh-mm-ss aa
if anyone has a more efficient suggestion I’m all ears, if not, I’ll use the new setup that seems to be working.
[quote=“MMaynardUSG”]in scripting I use the following to set date strings to valid date formats
[code]
inputFormat=SimpleDateFormat(“yyyy-MM-dd HH:mm:ss”) # Must match the format of the input string
outputFormat=SimpleDateFormat(“yyyy-MM-dd HH:mm:ss”) # The format you want to convert to
event.source.parent.getComponent(‘Power Table’).SDate=processedDateIn
event.source.parent.getComponent(‘Power Table’).EDate=system.date.addMinutes(processedDateIn,7)
[/code][/quote]
Thanks for the quick response. In this case I don’t use any scripting. just use my expression tag refrences in my SQL query. as I mentioned in my latest reply the problem seems to have been fixed with the couple of tweaks I made so we’ll see how that goes.
