I'm trying to use a unique license path other than just license.html in the build directory of the project (in this case license/license.html)
Stacktrace is as follows:
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal com.inductiveautomation.ignitionsdk:ignition-maven-plugin:1.0.12:modl (default) on project map-panel-build: Error creating modl file.
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:212)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:863)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:288)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:199)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
Caused by: org.apache.maven.plugin.MojoExecutionException: Error creating modl file.
at com.inductiveautomation.ignitionsdk.IgnitionModlMojo.createModlFile(IgnitionModlMojo.java:406)
at com.inductiveautomation.ignitionsdk.IgnitionModlMojo.execute(IgnitionModlMojo.java:210)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:207)
... 20 more
Caused by: org.apache.maven.plugin.MojoExecutionException: Could locate license.html. Check path in pom configuration.
at com.inductiveautomation.ignitionsdk.IgnitionModlMojo.findLicense(IgnitionModlMojo.java:498)
at com.inductiveautomation.ignitionsdk.IgnitionModlMojo.createModlFile(IgnitionModlMojo.java:392)
... 23 more
Caused by: java.nio.file.FileAlreadyExistsException: C:\Users\TRAVIS~1\AppData\Local\Temp\modl6165505976618970542
at sun.nio.fs.WindowsFileCopy.copy(WindowsFileCopy.java:124)
at sun.nio.fs.WindowsFileSystemProvider.copy(WindowsFileSystemProvider.java:278)
at java.nio.file.Files.copy(Files.java:1274)
at com.inductiveautomation.ignitionsdk.IgnitionModlMojo.findLicense(IgnitionModlMojo.java:488)
... 24 more
This is a separate error than when it couldn't find the license file, it looks like its trying to copy the file to the path of the temp folder directory rather than a path that corresponds to the license file below it.
It also looks like this issue was identified previously here, although it hasn't seem to been addressed.
Any insight would be appreciated, thanks!
