/usr/local/bin/ignition/data/config/resources/.resources explosive growth
Using Ignition Maker 8.3.1, I just recently had an issue where the drive ran out of space (only using 20GB) for the linux partition, but found that the /usr/local/bin/ignition/data/config/resources/.resources directory had grown out of control for some reason, and caused the gateway to stop working. I cleared the folder and generated a new license key, and it was fine for a few days until it happened again. That folder is filling up with tons of files of names that have no meaning to me. What is causing this to fill up so fast and how do I stop it? I have maybe 50 tags and 4 scripts that run, nothing insane.
This should be fixed as of 8.3.4, so you'll want to upgrade.
